Haier hwr10xc6 Air Conditioner Logo
Posted on May 31, 2008
E1 error code displays when unit is plugged in
  • 11 more comments
  • DePayne Jun 02, 2008
    Air conditioner will not turn on. Error code E1 is displayed and nothing happens. When you press the buttons you hear 2 beeps that that's it. It's about a year old and worked last year.
  • Cordova Diving Jun 05, 2008
    Two days ago, the unit quit working and displayed the E1 error code. I unplugged the unit and let it sit for 10 minutes. When I plugged it back in, it worked fine until this afternoon. Now the unit has stopped working and displays the E1 error code and unplugging it has no effect.
  • GlowinFalkor Jun 06, 2008
    Mine does the same thing. I can't find what it means and it's driving me nuts. If anyone can figure it out, please please tell us!
  • Anonymous Jun 23, 2008
    E1 comes up when pluged in but works with remote
  • laurendj2 Jul 06, 2008
    I have the same E1 error message and my remote is broken. What do I do?
  • ewpiii Jul 10, 2008
    I too have this issue. I have the Haier HWR12XC3 unit which was donated to us by my wife's father. Very hot in the house now. I get the E1 error. I tried to un-stick some buttons that may have seemed stuck. The "start" button seemed stuck but I can get it unstuck by tapping the panel next to the button. Still no fix. I also tried the unplug, plug in while holding the on/off button. Unplug, let stand 5 minutes, plug back in. Still no fix.
    Does anyone have a remote i can buy? I hurting over here. Thanks: e3
  • Anonymous Jul 10, 2008
    I also had the same problem. I found my remote and pointed it at the ac to turn on and it worked!!!. You need to find that remote.
  • Anonymous Jul 22, 2008
    I get ei error. Reset does not work and remote is broken
  • surama Aug 09, 2008
    Quick solution to the E1 display problem - the remote will still work the AC.
  • Anonymous Aug 20, 2008
    I just had the same problem no an hour ago. E1 showed on display, and none of the buttons on the AC worked, not even the power button.
    SOLUTION:
    In the past, I've noticed that my universal remote sometimes changes something on my AC when I'm trying to change something on the VCR. (My AC is in the living room.
    Well, I saw that the buttons on the AC wouldn't work no matter what I do. So I go get my universal remote, press the DVD/VCR mode button at the top, then just start pressing random buttons until something happened. I've got it now. I can control everything on the AC with it:
    The remote is a 'One For All' URC-3021B00
    The buttons are as follows:
    rewind=power on/off
    pause= timer on/off
    4=low/high
    5=temperature up
    9=temperature down
    8=fan/cool
    Here is the remote:
    http://www.oneforall-na.com/remote.php?t...
    Hope this helps.
  • Anonymous Sep 06, 2008
    the remote doesn't work nor does my tv/dvd remote
  • Anonymous May 25, 2009
    plugged ac unit in and it will not come on it just has the display E1... How do i fix this?
  • daddys_gi933
    daddys_gi933 Jul 23, 2012
    Air conditioner will not turn on. Error code E1 is displayed and nothing happens. When you press the buttons you hear 2 beeps that that's it. It's about a year old and worked this year.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25837
Points
13
SOLUTION:
rewind=power on/off
pause= timer on/off
4=low/high
5=temperature up
9=temperature down
8=fan/cool
Here is the remote:
http://www.oneforall-na.com/remote.php?type=URC%203021
Hope this helps.
  • Anonymous Jul 07, 2013
    What type of VCR did you have the remote programmed for?
Anonymous
Level 1:
  • Posted on Jun 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25837
Points
9
I'm having the same problem with the HWR08cx7. I called Tech Support at Haier and was told that this error code usually means that the control board thinks that a button is pushed in. The suggested fix was to "play around with the buttons and see if they unstick." The unit is less than 8 months old but the WILL NOT exchange/repair without the original receipt. Every other company honors thier warranty based on the serial number - doesn't matter about the receipt. Haier refused to honor the warranty at all. Will be contacting their corporate office and also the corporate office for Wal-Mart as that is where I purchased the unit. I suggested that Haier put a sticker on the outside of the units warning that they were "disposable" air conditioners . . . and not to expect any quality to the unit at all.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
31234
Points
9
E-1 Ok i just fixed my HWR 08 XC___ these things should work on most all touch panel models. Note some slight skills required. Ok 08= 8,000 btu 06= 6,000btu exct "size"
Ok Code E-1 = electrical problem "yes"
Mine first started had to be set low and read a lower temp than the room "coils dirty" then week later it showed E-1 and an hour later would trip the plug breaker. Root cause Dirty Coils "evaporator inside" can get ice from reduced air flow making ice n water n throwing drips. when to much of it floods electronics box and faults main to E-1. -drain clean and use remote. ok now to fix other stuff "unplug" remove filter and front cover 2 screws side 2 under filter. Do coils look cruddy ok, sprayed my coils with "gunk engine cleaner" with unit on side so electrics were up and rinsed with thumb over hose for fan spray from two feet away,now though you must first remove the snap in control panel "squeeze tabs and then its metal mount cover for its internal plug 2 screws one is in foam seal then lift and pivot."has tabs" don't wet the electrics or the plug breaker " "see the silver cans in the electric box"capacitors they hold a high voltage charge" stay away. Ok now clean and spray off the rear outside coils. then when done, tilt and and then u must even flip it over till all water is out, "Yeup i got wet too"..now dry electrics for an hour with hair dryer on low and then dry control panel back side on low 15 mins, now exercise touch buttons gently then dry them again. air dry assembled unit a day in sun to be safe
The cause of this "not so fun project" is plain old dirt and water build up a shure sign of this is unit seems to vibrate more or rumble "crud on one side of fans from stopping in puddle when unit is off and drain is clogged or unit not level or slops to inside.
Now with every thing dry, use a ground fault outlet first to test how dry you got it, and have a Firemen and a Paramedic helping you...Now hold the on button and plug it in. "good luck" if no go try any units remote most are quite similar...PS remember the E-1 unit most likely still works fine "Tarzan"
Anonymous
Level 1:
  • Posted on Aug 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25837
Points
6
We had this same problem...none of the below helped out. We have a Haier Brand. We were able to start it once but after that the E1 Error wouldn't clear and prevented us from using.
It appears that after 720 hours of use the E1 Error comes up as a reminder to clean the filter the filter. Although as in our case the E1 Error never cleared...below is what helped us out in clearing this code...this was for a Sharp but worked fine for our Haier Brand.
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
  • Anonymous Jul 04, 2012
    THANK YOU !!
    This worked exactly as described. You saved me from almost throwing this unit away. I was 2 minutes away from doing until persistence led me to the interwebs.
  • Anonymous Sep 05, 2012
    THANK YOU TOO! I through one Haier away because of this SAME PROBLEM. I though: "Who would have a problem like this? No company would sell a product with all these problems." Sure enough! Thank you so much - I'm glad I looked! I woulda thrown this one out too and gone and bought a new one. I should send you half the money if I'd gotten another one - I'd be out big time - they're scarce this time of year - and never knew! Haier should've sent something out. I don't think I'd buy another one of their products.
Anonymous
Level 1:
New Friend:
  • Posted on Jul 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25837
Points
The E1 problem could be as simple as wet wires. If the problem happen after you emptied out water or after you had an ice build up. You may just have some wires that need to dry. Take off the front panel and wait. Then try to plug it in again and test it out. That worked for me
Anonymous
Level 1:
New Friend:
  • Posted on Jul 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25837
Points
My E-i error was due to water in the control panel/ Like the top post, the trick is some disassembly, take off the interior radiator shroud with filter (two screws on sides), clean the fins, why not since you are in there. unscrew the circuit board. bust out a hair dryer and dry things off. real good! remember to push the buttons while using a hair dryer, the water is inside the buttons after all. after 15 minutes and a couple of trial plug-ins, things were back to normal. Woot! reassemble and enjoy. -B
  • Scott Weir
    Scott Weir Jun 18, 2014
    Not exactly, but by suggesting along with others that the problem likely had to do with the control panel it encouraged me to take it apart, as I have been doing for 60 years. John Muir suggested the same in the "VW Idiot Book." Sure enough, there was a bug on the circuit board, or the remains of one. Contact cleaner and a toothbrush and all well. This has happened to me before.
Anonymous
Level 1:
  • Posted on Jul 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25837
Points
I brought one of those giant universal remotes from kmart. although the thing didnt work for my direct tv receiver, the DVD function controlled my haier air conditioner perfectly. I got the e1 error early this morning, 7/24/2008 and with the 10 bucks i spent on the piece of **** that didnt work the way i wanted it too, it saved me a lot of time and trouble. Also, some cheap universal remotes (with some tinkering with the codes) can be compatible with air conditioners. Try it, or you can take the thing apart or pay 10x the amount for it to be fixed. Let me know at lingling314@gmail.com if it works for you..
Anonymous
Level 1:
  • Posted on Jun 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25837
Points
JUST HAD THE SAME PROBLEM,I WAS GO NUTS.JUST USE THE REMMOTE, IT FIXED THE PROBLEM.
Anonymous
Level 1:
New Friend:
  • Posted on Jul 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25925
Points
I had same problem with E1 showing up and disabling the touch pad .I took front cover off and unsnapped the touch pad from frame of AC and took out the 5 mounting screws and CHECKED each of the switches to make sure that they free ,while disassembled I plugged it back in to see if that cured the problem and IT DID , I reassembled touch pad assembly then cleaned the dust off fins and cover .I guess I am good for another 720 hours of COLD AIR . THANKS for the HELP.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25837
Points
Hey, thanks everybody. The Little Jesus prayer to find the remote - and it worked perfectly. Try this if you can...
Aaron Kirk
Level 1:
New Friend:
  • Posted on Aug 13, 2016
Aaron Kirk
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25837
Points
I cleaned my Haier unit today for the first time since purchasing it in 2002. I've been having issues in the past few weeks w/ water leaking out of the unit & a knocking noise that would come & go. When I tried to turn it on, it would not do anything. After reading some of the above tips, I took it apart again and used a hair dryer & made sure there was no moisture whatsoever in the unit. I tried it again & it works like a charm. I know they usually last 5-10 years, so I'll consider having mine for 14 years a success. And I will now complete yearly maintenance until it dies in me.
  • Aaron Kirk
    Aaron Kirk Aug 13, 2016
    An E1 code did come on & I do not have the remote it came with & I tried to use a universal remote without success.
Scott Weir
Level 1:
New Friend:
  • Posted on May 11, 2015
Scott Weir
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25837
Points
More on the E1 error: When I opened up my Haier ESA412K-L (12,000 BTU) for its annual de-bugging, instead of one dead roach I found two live ones! (This is the original "bug in the machine," at least in computer legend.) I've had this problem with electronic controls before, and generally brushing off loose roach parts and maybe spraying a little contact cleaner does the trick. This time, after spraying the contact cleaner and scrubbing the "wire" side of the board I added a little Raid bug poison. Bad idea: The Raid is conductive, AND it gums up the board. More contact cleaner, still E1. After taking the board out and cleaning the component side and a couple more similar rounds, I unplugged it and got it under a strong light. I found little streaks left by the Raid and the toothbrush (verifying they were ON the "printed" wires rather than gaps in them by scraping), and also several other little areas that looked suspiciously like roach droppings across two or more conductors. After several more squirts of contact cleaner and meticulous scrubbing of dirty areas with a Q-tip, I reinstalled the board and it worked normally. My unit does not seem to require plugging it in while holding the Power button in. Chances are, most of these units work very similarly, and I know from experience that roaches like circuit boards, though I don't know why. None of this requires any real technical knowledge, just caution, contact cleaner, and very careful cleaning on both side of the board.
sher dil
Level 1:
New Friend:
  • Posted on Nov 04, 2012
sher dil
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25837
Points
When i strat my air condetioner its not work its just show E1 error
Anonymous
Level 1:
New Friend:
  • Posted on Aug 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25837
Points
I have a haier air condintioner that fits in my window i dont have the problums listed above .. i got this air condtioner from my grandpa. he lost the remote to it and without one all yoy can do is turn the thing off and on..when i turned it on, its on a fan setting and low speed. i really want to get it to go high speed and on cool. there anrt any other butten but then power switch, im a girl and dnt have a clue on how to go about fixing it so if any one has any suggestions please let me know.
  • Nicci James
    Nicci James Sep 21, 2017
    Hold the power button down for 5 seconds when you turn it on.
  • Nicci James
A
Anonymous
Hi all. I had the same exact problem with the E1 message and the power button sticking. None of the buttons on the AC now work - the reset button and test button did not work. HOWEVER for some reason, that remote control turns it on! You've got to find that remote, it seems to be the only way. So weird.
A
Anonymous
Heres what i did just got the problem 'E1' after a power outage. Hold ALL the buttons in on the panel for a few seconds and then use the remote to switch things, after that it should work. Or it worked for me....I also punched it a few times
A
Anonymous
I had same problem. Using the remote powered it on.
A
Anonymous
Haier Customer Support indicated to me that an E1 code indicates an internal electrical problem.
They told me to return it to the store for an exchange.
A
Anonymous
This won't fix it but try using the remote.
Anonymous
Level 1:
New Friend:
  • Posted on Jul 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25837
Points
The Universal remote thing above works. I Have a remote Given to me by my cable provider. The provider is mediacom. I don't know how in the world this happend but all the controls listed above worked.
Anonymous
Level 1:
  • Posted on Jun 25, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25837
Points
Take the control panel (red) one and plug it back in and then you will have power again..
3 Related Answers
Anonymous
  • 555 Answers
  • Posted on Jun 05, 2008
SOURCE: E1 error code
You can contact Haier Technical Support here to open a support case for this error.
Frank Chen
  • 330 Answers
  • Posted on Jul 03, 2008
SOURCE: Error code
Do you still the warranty for this unit? maybe you should contact the company which you bought the unit.
Anonymous
  • 11 Answers
  • Posted on Sep 13, 2009
SOURCE: samsung AQV12m e1 error code
Check the wiring. If it's okay, reset by switching the power from the outside unit off for approx. 1 minute.
Top Haier Heating & Cooling Experts
Paul Carew
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
