Heating & Cooling Logo
Posted on Jun 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E1 error code on air conditioner - Haier HWS08XC1 8,000 BTU Window Air Conditioner
  • 1 more comment
  • Anonymous Jul 03, 2008
    E1 error code on Sharp AC
  • tldwork Jul 09, 2008
    Haier HWR05XC1 E1 error code on my machine. Leaving it unplugged all day did not do anything.
  • shar1104 Jul 26, 2008
    My unit stops working only after a minute, an E1 appears on the display. The only way to restart the system is to reset the power adapter. Then the unit restarts and then shuts down again within the small amount of time.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
12879
Points
13
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
  • Terry
    Terry Aug 25, 2014
    Tried this one but didn't fix ours....Still shows E1 Code. When I called Haier they told me it was a temperature sensor code :(
Anonymous
Level 1:
  • Posted on May 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
12879
Points
I have a voltas veritas AC. I was getting the same error E1 on display on power ON. Reason was malfunctioning of sensor.
Simply replace the sensor and it will work fine.
Raylin Sutter
Level 2:
Sergeant:
  • Expert 107 Answers
  • Posted on Dec 08, 2015
Raylin Sutter
Expert
Level 2:
Sergeant:
Answers
107
Questions
0
Helped
278919
Points
610
Last month my error E1 came on my air conditioning unit. It turns out that there was a huge malfunction in the system and it was sensing that. It wasn't worth my time and so I decided to just get a new system and the new installation is working great. I know that normally you don't just go out and buy a new system, but mine was getting fairly old. How old is your system? Air Conditioning Installation Repair near Lakewood CA
5 Related Answers
Anonymous
  • 133 Answers
  • Posted on Aug 02, 2007
SOURCE: Problem with samsung aw0503b
Found this on Samsungs site.Hope it helps a little, at least you know the problem now. If your air conditioner displays E1 in the display panel and won't turn on, it means that the Room Thermistor (a device connected to the thermostat that detects room temperature) is shorted or defective, and you need to have your air conditioner serviced. If it displays E2, E3, or any other E error, you also need to have your air conditioner serviced. To arrange for service, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have the model number of your air conditioner on hand when you call.
A
Anonymous
  • Posted on Jul 21, 2008
SOURCE: reset air conditioner
This did it for me! Same procedure but its described a little more thoroughly here...
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Anonymous
  • 742 Answers
  • Posted on Feb 13, 2010
SOURCE: boston innovative products MOB 10KDCHR portable
i found the user manual for it at:
manualfox.com/link/bostoninnovative.htm
Anonymous
  • Posted on Feb 09, 2011
SOURCE: error code E1 54 on samsung air conditioner split
A Bit of a late reply but E1 54, is indoor fan fault.
A
Anonymous
  • Posted on Jun 11, 2008
SOURCE: error code on air conditioner
Sharp inverter Air conditione.
After approx 20/30mins the system shuts down and shows a 6 on the display.
Any ideas.
Has been service
Top Haier Heating & Cooling Experts
Paul Carew
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
