20 Most Recent
Bosch Exxcel WFX 3267 Front Load Washer Questions & Answers
Leak detergent drawer
If the machine has been moved recently, ensure that it is level and not leaning forward. Pull the dispenser completely out (pull as far as it will go, then press down on the blue section in the fab cond compartment to fully remove) make sure it is clean and free or fab cond and powder build up. Following the diagram, check that part 0412 is clear (this can be done when the drawer is out by putting some water in the dispenser manually and seeing if it flows quickly. A baby bottle brush can be used to clear it, if it is blocked.
My Bosch Nexxt Front Load
(no promises but it's worth trying this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
I have a bosch logixx8 washing machineand door is stuck how can I open it
To open the stuck door on your Bosch Logixx 8 washing machine, first ensure the cycle has ended and the child lock is deactivated. If the door remains stuck, locate the emergency release mechanism, typically found behind the drain cover at the machine's base. Open the cover, identify the release tab or pull cord, and gently pull it to unlock the door. If issues persist, it's advisable to consult a professional technician.For a visual guide, you may find this video helpful: https://www.youtube.com/shorts/yeD5oFpFjsw
My machine is tearing apart sweaters
Even in "gentle cycle"?
Use a nylon mesh garment bag (it has a zipper on it) available at Target, WalMart, etc.
Use a smaller one mesh bag for lingere, too.
Hi. Have a Bosch Loggix 8 VarioPerfect WAS32440AU. It has been displaying a uPd code. Was hoping that you can verify the issue. TIA Brian.
I know that this is a very old question, but for anyone else looking for an answer, uPd isn't an error code, it's just the machine telling you that there's a firmware UPDate available to install for your washing machine. Check your manual for how to do this, but for me it was a matter of holding the 'Remote Start' button for about 3s until the machine entered the service menu, turning the main dial until the display showed uPd, then pressing the 'Start' button to initiate the update. After probably about 5 minutes of a spinning progress indicator, 'End' appeared to show that the update was complete.
Bosch vision 300/500/dlx washer drum fills with water when the washer is turned off
???? ??????? ?????????? ?????? Bosch Vision 300/500/dlx ??????????? ????? ??? ??????????, ????? ???? ????????? ??????, ??????? ????? ?????????:
1. ???????????? ?????? ??????? ?????? ????: ???? ?????? ?????? ???? ?? ??????????? ?????????, ???? ????? ?????????? ????????? ? ??????? ????? ?????????? ??????. ? ???? ?????? ????????????? ?????????? ? ??????????? ??? ?????? ??? ??????? ???????.
2. ???????? ? ????????? ?????? ????. ???? ??????? ?????? ???? ?? ???????? ??????? ???????, ?????? ????? ??????????? ?????????? ??????? ???? ? ????????. ??? ????? ???????? ? ???????????? ?????? ??????? ?????? ????. ? ???? ?????? ????????????? ?????????? ? ??????????? ??? ??????????? ? ?????? ??????????? ????????.
3. ???????? ? ??????????? ??????? ??????????: ??? ????????????? ???????????? ?????? ?????????? ?????????? ?????? ?? ????? ??????????? ???????? ?????? ?????? ???? ? ????????? ? ?????????? ???????? ????? ??????????. ? ???? ?????? ????????????? ?????????? ? ??????????? ??? ??????????? ? ??????? ?????? ??????????.
4. ?????????? ??????? ?????. ???? ??????? ????? ??????? ??? ????????, ???? ????? ?????? ????? ??????????? ??????? ?? ????????. ??? ????? ???????? ? ??? ?????????? ??? ??????????. ????????????? ????????? ??????? ????? ? ??? ????????????? ???????? ???.
???? ???????? ?? ????????? ????? ???????? ????????????? ??????, ????????????? ?????????? ? ????????????? ??? ? ????????? ????? Bosch ??? ????????? ?????????????? ?????? ? ??????.
