Ricoh Aficio Mp 2000 Copy Machine Logo
M
Max Ackermann Posted on May 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the error code 391? - Ricoh Aficio Mp 2000 Copy Machine
John Ray
Level 3:
  • Master 790 Answers
  • Posted on May 08, 2014
John Ray
Master
Level 3:
Answers
790
Questions
0
Helped
192153
Points
2180
This link may give you more incite on your error code problem
Haam washing machine error e2
Never heard of the make 'Haam"? Perhaps you mean 'Haier'? Anyway, it might be a generic drain error
An E2 Error code indicates that the washer is still draining after 8 minutes. Check the following: Check that the drain hose is not more than 391 ?3" (100 cm) from the floor. Remove any clogs from the drain hose.
E2 - Error Code - Stacked Laundry Center - Product Help
Code for HT-391 regent home theater remote
my name is travis i have a regent home theater system model ht-391 i just bought a universal remote is there a code for the system
2helpful
Error code 391 paper jam - no paper jam though. Open front cover and close and that resets machine but when you try to print error code 391 again!
Check the area where its showing the paper jam to see if there are bits of paper there. Most of these issues are caused by tiny pieces of paper blocking the sensors.
Keep gettomg error message 388
Hi There,
HP Support provides definitions and solutions for it's printers.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
At this site you can simply scroll down and click on the blue underlined link "388" which states,
"There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time."
"Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve."
Since you didn't state that you were having a problem sending faxes, I fear this is limit to which I can assist you. That being the case, please reserve negative feedback for HP if the solution isn't sufficient.
If the error persistes and you are not attempting to send a fax unsuccessfully, it would indicate a false error report and that your registry in your operating is a bit out of order where the printer is concerned and the best "final" solution would be to uninstall the printer from the Control Panel COMPLETELY, then hold down the WIndows logo key and press the R key. A Run window will appear. Type in %temp% and hit ENTER. Your Temp File folder's contents will appear. Left click one in that window and then hold down the CTRL key and hit the A key. All files will be selected. Hit the Delete key. Remove every file that Windows will allow and then close the window, Disconnect the printer from your computer. Then go here:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Officejet+6210
Select the correct version of your 6210 (there are 3). At the next page Download the Full Version software by saving it to your Desktop. Then double-click the software installation file and follow the prompts. Do not connect your printer until the software prompts you to do so.
Ciao for Now
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
3helpful
Sky remote code for lg m227wdp sky remote is rev 6
press tv button
then red and select together for 2 seconds the led should blink twice
enter the code
press select
try it...
one of these codes should work... but its a bit trial and error 0056 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
good luck
1helpful
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
Unknown error 009-391
Remove Cyan Cartridge. Trun Off the Machine.
Now Insert Cartridge, make it properly inserted.
Trun On the Machine And The Error Is Gone......
Try It
HP Officejet 4315
HP Support Web page
<http://tinyurl.com/lbwcwd>
Error Code:
Solution
The 391 code problem
SC 391 is image storage address error. Development BIAS leak. Charge AC output error.
Should be checked out by a technician. It could be a few things going on with it.
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
