HP FAX 1250 Fax Machine (Black) Logo
Spinnakers Restaurant Posted on Sep 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 388 - HP FAX 1250 Fax Machine (Black)
Antonios
Level 2:
Scholar:
  • Expert 55 Answers
  • Posted on Nov 16, 2022
Antonios
Expert
Level 2:
Scholar:
Answers
55
Questions
0
Helped
30961
Points
172
The error code means that The remote machine has failed to respond to a fax command from the local machine because the connection is interrupted. If you've successfully sent faxes to this number before, then you can reattempt the fax transmission at a different time when line conditions have improved. You can also run a fax test from your printer and check if all tests pass. A line test can also be run by your telephone company to ensure stable fax line conditions.
You can also disable Error Correction Mode by Setup menu (on printer) > Fax Setup > Advanced Fax Setup > Error Correction Mode > Off.
Regards,
Peter
Reuel Teoh
Level 2:
Champion:
  • Expert 411 Answers
  • Posted on Dec 20, 2013
Reuel Teoh
Expert
Level 2:
Champion:
Answers
411
Questions
Helped
116319
Points
490
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
1helpful
An error 388
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395Definition
Solution
1helpful
Fax Error 388
Solution
12helpful
3answers
Error code F14 ON DISPLAY FOLLOWING MASSAGE "CALL FOR SERVICE" SUGEST SOLUCTION FOR THIS CODE
F14 indicates invalid backup counter.
After cleared below counter, problem is solved.
*Method: Just enter 08 setting mode-->key in "388"-->press Start button. Repeat again for "389"
*After cleared the counter, it will also reset the network settings where we need to reconfigure.
1helpful
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
HP Officejet 4315
HP Support Web page
<http://tinyurl.com/lbwcwd>
Error Code:
Solution
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Error 388
Error 388 means refers to telephone line conditions, have you called you telephone service provider and have your telephone line checked.
If not please have it done.
For breif reasons on error codes check the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=79477
Good Luck
Sending faxes
Error 388 is for telephone line conditions being bad, have you called your telephone company and head you telephone line checked...?
If not please have it checked.
For more details on the error message check the link bellow with Error codes any their reasons:
Good Luck
Fax
error code 388 says :-
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
