20 Most Recent HP OfficeJet 7410 All-In-One InkJet Printer Questions & Answers
Printing landscape instead of portrait
this article may explain how to change it http://hints.macworld.com/article.php?story=20070613051850612
7/25/2021 7:30:02 PM • HP OfficeJet... • Answered on Jul 25, 2021
Ink cartridges stuck on left side of carriage. Won't move. Tried all of the suggestions and still says carriage jam.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
7/25/2021 7:05:43 PM • HP OfficeJet... • Answered on Jul 25, 2021
2answers
How do you do a
Basically removing power is all you have to do to reset the printer. However, if you need any other information, here is the link to HP for your printer: http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=391194&
3/2/2021 7:59:20 AM • HP OfficeJet... • Answered on Mar 02, 2021
34answers
No HP devices detected. HP Solutions Center will close now. beware spam number 1800-975-0148 below
By this time, I may be an expert on this particular problem(that's a joke because anybody having this problem KNOWS that nobody has a solution, even, and especially HP). Sometimes you put so much time into something that it becomes personal(or stupid). But I did resolve this problem and I have done it 3 times(not by choice) so I feel this will work.
First and foremost, for anybody considering HP. Don't. Their hardware seems OK, but the software and support is awful. Don't even waste your time calling them.
Second, this is a painful process. Some that know better about registry updates may have a better solution, but I did it the hard way. So plan on spending a few hours to get through it.
Third, I don't know if this is important or not but buy a registry cleaner program. I used Registry Mechanic from PC tools. I am certainly not touting that product and I found some issues with it, but it's just what I used.
Fourth, this process works. But I'm going to be somewhat vague because I'm so tired of working on this issue that I don't want to take the time to provide exact detail. However, anybody that knows anything about Windows will understand this.
Here is the magical process(I have a HP 7680, but I think it will be the same for all models)
a) Uninstall the #?!!!$! HP software using the Uninstall from Control Panel.
b) Download the latest HP software for your printer from their site.
c) Run the Level 2, Level 3 and Level 4 Uninstall programs in the CCC folder of the software you just downloaded from HP(or, on the HP CD if you cannot download the latest version).
d) Scan your hard drive and delete any and all HP folders, including the "Hewlett Packard" folders. PLEASE NOTE: You probably will not be able to delete some folders because files are in use. You must delete these folders. Either reboot in safe mode to delete them, or shut off all services in msconfig(reboot required).
e) Delete the Twain32 folder in Windows folder
f) Empty the Recycle bin(probably not important, but I was taking no chance)
g) This would now be a good time to run your registry cleaner. This program should remove all registry entries that point to files that don't exist anymore. Registry Mechanic did not do this completely for whatever reason, but this should make the next step
h) backup your registry. The way I did this was "Start", "Run" and type msconfig. Click "Launch System Restore" and "Create a Restore Point". Do this, but be warned that there were a few times I tried to restore to one of these and the Windows process was unsuccesful. Didn't investigate why, but it happened, and more than once.
i) now the time consuming part. You are going to delete at least many hundreds of entries so get comfortable. Open the registry edito(regedit) and start scanning for these values. When you find them, delete the entire key, not just the key value(i.e. delete the folder on the left side of the regedit window). Sometimes you will get access denied. Just right click on the key and click "Permissions". Change the "Everyone" group to have full permission, then delete the key. This doesn't happen often - maybe 10 times? Also, please note that sometimes you will see that where the value was found, it has nothing to do with HP and so I left them alone. I would estimate 99% of what I found, I deleted. Believe me, you'll get good at this and your eyes will quickly identify the fact it's from an HP installation.
During this scan process, you will find reach a point where on the left side of regedit, there are dozens of folders that start with HP, all lined up nicely. Delete ALL of them.
1) Scan for and delete any folder(key) that contains "\hp". This is the hard one. Hundreds of them. (why didn't these get deleted by my registry cleaner program???)
2) Scan for and delete any key that contains "AIO"
3) Scan for and delete any key that contains "hp " (that is hp followed by a space. The search function allows this
4) Scan for and delete any key that contains "digital imaging"
5) Scan for and delete any key that contains "hewl"
j) almost there, and don't mess this part up. Make sure your printer is NOT connected. Reboot.
k) Reinstall using latest version. During installation, choose that you don't want HP software to check for updates and also, check the "custom" installation. When you reach the screen that lets you pick which programs to install, uncheck ALL of them that you can. You only want to install what is required. The rest is JUNK. When you reach the point where it wants to find the printer, do NOT hook the printer up. The software will assume you will hook it up later. Finish the installation and reboot.
l) run the install again. This time the menu will say "Add a device". Go ahead and click on that and hook up your printer(use USB). I did discover on one of my trips through this maze that it found the printer and installed it nicely, BUT, when I started HP Solution Center, it did not display the device. Then I ran Setup again, tried to install it as a network printer(cabled-not wireless). This failed but then, there it was the next time I opened Solution Center!! The process of trying to install network printer fixed something so don't give up once you get this far.
m) Good luck with this. I feel for all the people out there that just can't afford to go buy another printer. Again, I wouldn't touch HP with a mile long stick. The only reason I wouldn't give up is I was PISSED. I actually did this for somebody else, but I work for this person, so felt obligated to solve it. And I have HP printers at home, but, after researching this issue on the Internet and seeing what all of you have written, I will never buy HP again.
3/2/2021 6:55:50 AM • HP OfficeJet... • Answered on Mar 02, 2021
Looking for the "HP Solution Center" icon
Printer assistant replaced Solution Centre a few years back. Either one will be in the full software download from HP The link will give you more information https://support.hp.com/us-en/document/c02463264
3/7/2018 11:41:37 AM • HP OfficeJet... • Answered on Mar 07, 2018
3answers
How do i install a new mother board on my hp
Well you wont find this info anywhere...HP doesnt give it out to anyone but authorized repair centers...
I dont think you know what that board costs....it may be cheaper to get a new printer...you probably cant get the board with out having a repair center do it anyway Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
10/27/2017 12:24:43 PM • HP OfficeJet... • Answered on Oct 27, 2017
Automatic paper feed does not feed paper.
If the rollers are okay the only think left is to replace the roller assembly which is pretty simple to do.
10/2/2017 6:33:51 PM • HP OfficeJet... • Answered on Oct 02, 2017
Hp officejet 7410 all-in-one scanner don't work half the time.
Perform a hard reset on printer and also uninstall completely all software and then reinstall. Try scanner again. If you have "upgraded" to another OS there is a possibility that the driver being used is not good for the new environment. If applicable, check that out. If printer is out of warranty HP will do nada but refer you to a forum or suggest you get a new printer - an HP naturally!!!!!!!
8/27/2017 2:37:20 PM • HP OfficeJet... • Answered on Aug 27, 2017
4answers
HP 7410 All-in-One
HP will give you a new printer for free. I just did this through online tech support tonite. My unit is 18 months old. When you use the online tech support, save time and use this link that they gave me after 45 minutes of explaining my problem. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01189384
8/3/2017 11:37:01 AM • HP OfficeJet... • Answered on Aug 03, 2017
HP OfficeJet 7410 All-In-One InkJet Printer Logo
898 questions posted
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
no hp devices detected hp solutions
  • Office Equipment & Supplies
