The Washer says that the pump is blocked. The manual says that I can open the pump cap and clear out whatever is blocking the pump (lint/loose change etc. that might be stuck there). However, I cannot open the pump cap? I can turn it about a 1/4 circle and then it does not budge! Any ideas?
The pump cap goes back into the machine about 7 cm (3 inches). It has openings that allow the water from the tank to drain during normal operation. However, if something (like a hairpin) is long enough to lodge between the cap's hole and the drainage tube then when you try to twist the cap open it jams against the offending item (hard to explain without a diagram). The only way to remove it is to tip machine up, unscrew whole pump unit, undo clips holing it in place and then pulling rubbish out. It's a pain. Then make sure the propeller is back in place, securely (or this will lead to more noise and refixing - which will be easier 'cos at least you can get the @#$#$% cap off now).
I found a diagram online of the cap so I was able to visualize why brute force might be a bad idea. I took the back off of the washer and remove the hose to the pump. Bingo, out came rather long piece of stainless steel. It kept the cap from turning all of the way. After much head scratching I finally figured out what it was. The underwire of a bra. I only mention that because it is a piece of metal that is frequently in washers and probably not thought of.
How did you get the cap off? Mine is stuck stuck, I'm about a 1/4 turn from open, and just broke the middle part of the cap
No need to remove the pump. I removed the black rubber hose from the pump and was able to remove the object that was preventing the cap from turning, a pair of long nose pliers was helpful. You may also need someone to help by rotating the cap left and right as you are removing the item.
Sometimes it just takes brute force to open the pump cap. Try wiggling a bit from side to side; if an odd-shaped item is lodged in there, it can really be tough (but possible!) to open.
Try tightening back up then loosen some more. I found by going back and forth it freed up the debris that was interfering with the unscrewing thread. e.g each time I unscrewed I got a bit further than before until it came out .. yuk no a nice job though :(
Just had the same issue. I was able to turn it about half a turn and then it felt really stuck. Going through some of the reviews here I decided to turn the damn thing as hard as I could( used a screw driver) and kept turning it, at some point it got stuck again, so I used even more power... It took about 5 or 6 coplete turns, and then you just need to pull it towards you and it pulls out.
In my case, I found a sock wraped all around the screw inside the cap, which was the reason it was so hard to pull out in the first place.
I used pliers on "bosch serie 6" and give it a hard turn into the left side. The reason it stucked was colour catcher paper.
It's not a nuclear science an it keeps money and time. ;-)
I had the same problem. What I did to get around it was too run a rinse cycle followed by a drain cycle with no spin. That moved things around enough to open the cap. Inside I found a bobby pin and a penny.
We had this problem, after draining the washing machine wiggling the pump cover it would come off. It only turned about a quarter turn. We fixed it by running a drain cycle only as described in the manual. This seemed to dislodge whatever was blocking the pump cover from turning freely (a nickel and dime).
I had the same problem and solved it by disconnecting the washer from the water and the mains and then laying it on its back, the cause of the blockage was then dislodged and I could unscrew the pump cover.
Thank you so much for all the suggestions above! I couldn’t release the pump cover cap on my Bosch WDU28 and spent ages draining the machine. A lot of your comments gave me the confidence to turn it back and forth with some force ~ and, at last, it opened!! The offending item...a shirt collar stiffener ~ pesky little thing!
Thank you everyone!
Thanks to all the comments here I was able to solve this problem (the pump cover was turning a 1/4 turn then wouldn't turn any further).
I ran a drain cycle as suggested and this didn't seem to help but it did at least finish the cycle (as I'd already manually drained the water using the hose), so I could take the washing out.
I managed to remove the pump cover by continuing to turn it backwards and forwards, with a decent amount of pressure when turning it forwards (by hand), and eventually it moved past the blockage (3 hair clips, 2 coins and some hair) and unscrewed.
Thank you everyone.
Tipped the machine left side down
Took off the hose from the pump unit by opening the wire grip and fished out bra wires, kirby grips, a one dollar coin, and some indescribable gunk
All better now
If you disconnect the main tube running from the machine into the pump (on the left, accessible if you remove the front bottom panel, held on by plastic snaps and one or two screws), you can then clean out any blockages that are preventing the cap from being removed just by snaking a finger in. Not too tough and no need to put the machine on its side. The tube is held on by one of those wire crimps, you will need pliers to get it off and back on again. Once youve cleared that out, the cap should be easy to remove.
I've done all of the above and Broke the middle part of the cap...I need help
I had same issue tonight! Was struggling for almost 2 hours to open it. Eventually I got it open with pliers. I wiggled it around a little and then twisted hard! It was kind of scary, because I was scared that I was gonna break the cap. It came off, and there was a naughty piece of metal wire that was causing the problem!
I tried everything to try and open the pump cap but it wouldn't budge. I eventually ended up breaking it and then removing the offending piece of cloth. Bought a new pump cap online but am still unable to open the old pump cap. help!!!
Cannot remove pump cap. Cannot get purchase on it to pull it as any
kind of wrech/pliers slips off & the plastic is too brittle to
force it without breaking it.
Poor
design!!!!!! All the instructions say is to "carefully remove pump
cap". what a croc. So alternative is to buy a new machine & throw
the whole thing out cuz the frustration here is enough to make me wish
I'd never bought this stupid washer in the first place! Will buy a
different brand next time! I have the Bosch Maxx WFL 2260. Please email a better solution to socoineen@yahoo.com thanks
!@#$% pump cap is all I can say and I will never buy another Bosch washing machine. I had a Pacific front loader before for 15years. Pity they stopped selling them here in Australia. The cap will only turn 1/4. There is no amount of brute strenght that will turn it. When it was new i tried to open the cap and even then it was stuck. WFL1800AU/20
I just broke the cap...
Your blockage is more serious than you realize. There will be excess debris blocking the removal of the filter as well. You will need to turn the machine over and remove the washer pump or more specifically the pump hose from it. Then clear the debris down there first. After that you can remove the filter to clean it out as well....
It is a fairly easy process. I found this video to explain perfectly.
https://youtu.be/sxlz0jvPPi0
So I just removed a bolt, 7 coins, a key, a button and a tonne of hard gunk from mine. I have no idea how the pump even functional in the first place. Washing Machine is 13 years old...
