20 Most Recent
Sharp Remote Control Questions & Answers
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
I WANT TO USE MY
Go to the Remote control Manufacturers website and get the instructions for the remote control. Then you need the codes for each of the items you are going to program in. You can get some of the Directv functions on universal remotes, but if it's a DIRECTV with DVR then the rewind functions, etc. may not work. Good luck!
I can not remove closed captioning on all my
As best I can tell, the TWC remote requires about 12 steps to turn CC on & off - very annoying and I can't understand why it's not simpler. Hit the blue menu button near the top; scroll down or up to Settings, hit enter, scroll down or up to Captioning, hit enter, scroll to how you want CC (off, on, or just when Mute), hit enter, then hit Exit to clear the screen. A pain, no?
Can My Comcast TV Remote Connect To A Sharp TV
the codes for Sharp LCD's are 10093 and 11602...follow the normal programming instructions but use these codes....newer remote manuals may have these codes but however the one i had didn't...hope this helps
Black and white captions
1.go to t.v. menu
2. go to close caption
3.turn it off
Toank you for useing fixya
please rate me
