IDEAL Powr-Glo Audible Voltage Tester Logo
Anonymous Posted on Aug 27, 2008
Usage How To
How do I test Outlet Voltage?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
849
Points
How do you read the lights on the Gardner Bender outlet tester? GRT-3500 I need easy instructions?
Anonymous
Level 3:
President:
  • Master 2,712 Answers
  • Posted on Aug 27, 2008
Anonymous
Master
Level 3:
President:
Answers
2712
Questions
Helped
742646
Points
8771
To measure the voltage at an electrical outlet requires the use of a multimeter. Always test your test equipment for proper operation before use. Set the multimeter to AC voltage. The markings may appear as VAC, AC V, or a V beneath a wavy line. Choose the AC voltage closest to the voltage you will measure. Standard current in home and businesses in the USA is in the range of 110 to 120 volts. Some circuits used for equipment such as dryers, air conditioners, electric stoves, ovens and other large equipment may use voltage in the range of 220 to 240 volts. These heavy-duty circuits can be identified by their non-standard outlet plugs. While grasping the insulated portion of the probes (never touch the metal conductor during testing) place one probe into each of the two terminals. The multimeter will display the voltage. Carefully remove the probes, being careful not to touch the metal part of the probes to anything or each other. The voltage should typically test in the range of 108 to 121 volts for most circuits. If voltage is higher or lower, professional electrical service may be required.
Top IDEAL Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an IDEAL Measuring Tool and Sensor Expert? Answer questions, earn points and help others
