Brother DCP-8040 Copier Logo
Posted on May 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 6a - Brother DCP-8040 Copier
Sudeep Chatterjee
Level 3:
  • Master 3,269 Answers
  • Posted on May 30, 2011
Sudeep Chatterjee
Master
Level 3:
Answers
3269
Questions
10
Helped
1178579
Points
10265
Solution 1:
Turn off the power
Unplug the printer power.
Wait 5 minutes.
Plug the power cord back in.
Solution 2 (resetting):
Enter in service mode: Press "menu,*,2,8,6,4"
"MAINTENANCE" appears on the screen.
Press 9,9 to exit out of maintenance mode and to start the warm up procedure.
(make sure that fuser is'nt hot before preforming the reset)
Anonymous
Level 2:
New Friend:
  • Expert 145 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
145
Questions
Helped
24862
Points
431
The fuser will need to replace
How do I fix Machine error 6a of my Brother Printer?
This error happens when the lamp of the printer fails to sustain a certain temperature within a time limit. You can fix this error by manually entering the mode of maintenance. You can press menu for entering into the mode and then focus on the display; if it is done rightly, the light will start to blink.
https://medium.com/@johnshort3190/how-to-easily-fix-the-brother-printer-error-code-6a-c78e91e789fc
Code f1 f3 f6
virtual machine - VNC send Ctrl+Alt+F1-F6 to server - Unix ...
unix.stackexchange.com/.../vnc-send-ctrlaltf1-f6-to-serv...
Stack ExchangeMar 15, 2012 - Hence I can switch to the TTY's if my CTRL + ALT + F1 - F6 ... As I understand it, you want to send CTRL-ALT-F3 to the remote .... What numeric keycodes do I need to send for the magic sysrq functionality in a VNC session?
error code f1 dishwasher model gldt696tss 00 KVM Switches
www.fixya.com > ... > error code f1 dishwasher model gldt696tss 00
KVM Switches error code f1 dishwasher model gldt696tss 00 questions and ... 6F 23 20 F1 01 = F2 46 B1 59 04 61 77 71 Telewest 00 = 75 4A 66 04 CF 7F 55 F3 ... ...96 F6 1F C4 01 = 6D EA BE 97 6A AA DA 71 NTL 54 01] 07/10/09 00 = F0 ...
kleenmaid f6 code KVM Switches Questions & Answers - Fixya
www.fixya.com > Forum > Tags > kleenmaid f6 code
KVM Switches kleenmaid f6 code questions and answers. ... 01 = C6 64 1D EF 47 5A 0E EF tellywest 00= B7 DE 73 DE 2F A4 F3 BO 01= FA 4B 82 4C ... ...in bradford area plz 5a 01 83 5D 12 B8 96 F6 1F C4 6D EA 8E 97 6A AA DA 71 Hope ..
Machine error 6A
Fuser Thermistor or Halogen lamp defective. maybe you need to replace the whole Fuser
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
12helpful
3answers
Machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
53helpful
5answers
Telewest codes for 6/10/09
00 = C2 B5 BE 41 0D 9B C5 7C
01- 6d ea 8e 97 6a aa da 71
3helpful
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
