Canon PIXMA MX700 All-In-One InkJet Printer Logo
Posted on Apr 11, 2011
What is error code b200 on a cannon mx700 - Canon PIXMA MX700 All-In-One InkJet Printer
5 Related Answers
Anonymous
  • 174 Answers
  • Posted on Nov 27, 2008
SOURCE: Cannon Mx700 error code 6a80.
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
Anonymous
  • 677 Answers
  • Posted on Nov 07, 2009
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
Anonymous
  • 37 Answers
  • Posted on Aug 02, 2010
SOURCE: Error Code B200
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Anonymous
  • 37 Answers
SOURCE: canon pixma MP480 printer error code B200. What is B200?
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Oct 16, 2010
SOURCE: printer comes up with error
Try this first. Please go to this link.
If the above did not work, try the second solution below:
1. Please open the printer cover and when the carriage head moves to center pull out the power cord.
2. The Purge unit is on the right side. Use a flashlight and you will see two ink pads. This is where the print-head is PARKED and is the top of the Purge unit.
3. There you will find wiper blades that move from the rear to the front. They wipe the bottom of the print-head when it is parked.
(The ink pads actually drop down about 3/4" to allow the wiper blade to pass and then it is supposed to spring back to the rear. Also the ink suction for cleaning the print-head is done by the purge unit.)
4. Use some rubber gloves and a paper towel and see if you can press the ink pads down just a little bit - about 1/4". See if for some reason the wiper blade is stuck extended, if so see if you can get it unstuck. Please do this gently such that you don't break anything there.
This error indicates that the purge unit is not giving the correct timing signal as it rotates inside 360 degrees. Therefore, something is either broken or jammed inside. If you had a paper jam and tried to forcefully pull it out, you could have pulled the internal gears out of alignment.
So you will need to do some maneuvers to try to release the cartridge from its parking position. Again, don't try hard.
Now, if this does not work than it would be cheaper to buy a new printer rather than sending it to Canon for repair if its not in warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
