SOURCE: lc-46d43u aquos lcd tv
The remote code 31 worked on my Motorola cable box.
The REmote is for a Sharp LC-32GP1U
The code was listed under one of many for Jerold. I entered codes one by one testing the secondary power button each time.
Code 31 works fine.
SOURCE: OWNER'S MANUAL AND A REMOTE FOR A SHARP SHARP 46'' TV MODEL lc-46s
The mauual you can get from the internet by Googling it will be in PDF format that you can print. The remote use a Universal cheap GE is good and program with one of these codes....
0079, 0123, 0063, 0020, 0004, 0009, 0226,
0266, 0006, 0095, 0122, Low cost approach.
SOURCE: i need sky remote code for sharp tv model no lc-32sh7e
Hi there. I hope you will see this reply. I bought one of these TV's yesterday and I've got the code from my dad's website www.satcure.net
If your remote is Version 6 then you will be able to follow the help on the sky box under
Interactive
Customer service
Program Remote
Then follow the steps using code 1221
If you have a Revolution 8 remote then you will have an easier job but with a 3 digit code.
3 digit code is 253
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn
on the TV receiver
2. Press TV on the Sky Remote Control
3.
Hold down SELECT and the RED buttons together for approximately two
seconds, until the RED LED on the Sky remote blinks twice.
4.
Enter three digit code from list for the receiver (early versions now
flash twice).
5. Press select to enter code structure (the LED
will flash twice if a valid code has been entered).
6. Now press
the STDBY button and test other functions.
Hope this helps/works!
