Televison & Video Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the code for an RCA remote model RCR311W for a sharp tv
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 04, 2011
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
Hello
Codes for Sharp TV with RCA RCR311w are
Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
Direct code entry method
1. Manually turn on the component
you want the remote to control.
2. Locate the enclosed Code Lists.
Find the list for the component you
wish to program. Find your
component's brand. You will see a
listing of four-digit codes for each
brand. If your brand isn't listed, use
one of the Code Search methods to
program the remote control. (Refer
to pages 7 and 9 for Manual and
Auto Code Search methods.)
3. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you
wishto program. The illuminated
ON•OFF key turns on and
remains on. If you release the
component key at any time
during the Direct Code Entry
procedure, the illuminated
ON•OFF key blinks four times,
and the process is exited.
4. While holding down the
component key, consult the Code
Lists for the four-digit code that
corresponds to your component's
brand and use the number keys
(0-9) on the keypad to enter it.
While you are pressing the
numbers, the illuminated
ON•OFF key turns off.
5. After the fourth number is
entered, the illuminated ON•OFF
key turns on. At this time, release
the component key. If the
illuminated ON•OFF key turns
off, you have entered a valid code
and have followed the correct
procedure for Direct Code Entry.
If you enter a code number that is not
in the Code Lists or you do not follow
all of the steps for Direct Code Entry,
the illuminated ON•OFF key blinks
four times when the component key
is released. This is an indication that
a programming error has occurred.
In that case, repeat the Direct Code
Entry process from step 3.
of each key, be sure to keep the remote
pointed at the IR sensor of the
component you are currently
programming the remote to control.
6. To confirm that the component key
is programmed with the correct
code for maximum functionality,
test the component. Attempt to
control a variety of the
component's functions with the
remote. If some of the features of
your components do not work, try
programming the remote with a
different code in the list until you
find the code that allows the
remote to control the majority of
your component's functions.
Different codes can provide
different levels of functionality
OK
Cant get my rca remote to work on ,my sharp tv i need the code for sharp tv the model onmy remote is rcr311w
Not really sure what to do here, whether or not its a universal remote you are referring to. The attached is a link for almost any users manual for anything electronic. Hope it will help you find the users manual with the correct code. http://www.retrevo.com/support/HP-m8150-Desktops-manual/id/3167ag902/t/2/
Mar 21, 2011 • Vacuums
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Universal remote code
i have a sharper image universal jumbo remote and i need a code for a sharp tv
Top Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
