When we turn the tv on a few minutes later it cuts off and the green power light blinks for a few minutes then the tv cuts on by itself. It keeps turning on and off but the green light just keeps blinking. Someone please help. TV does the same thing. Sometimes. Turn it on and after a few min. it turns itself off. The green light flashes when it turns off. 30 sec. later it comes back on, after a few min it turns back off, --keeps repeating--
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
The local Sony Dealer where I bought the TV told me to unplug the tv for a while. There is a computer in the tv that sensed a problem and keeps triggering the shut down sequence. I was leaving for the weekend so I cut power for 3 days. When I plugged it back in, it started working fine. I did not replace the bulb.
The Best Solution worked perfectly, I replaced the XL2200 Sony Bulb and the TV is up and running again!
Thanks for the help.
BobE.
Change the lamp
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
When turning the television on it will power up and turn off within seconds.The green light blinks and blinks and then the red light comes on and the tv shuts off.
I HAVE REPLACED THE PROJECTION LAMP THREE TIMES IN 5 YEARS AND DO NOT UNDERSTAND WHY THIS LAMP KEEPS GOING OUT. I WOULD NEVER HAVE BOUGHT THIS TV IF I HAD KNOWN IT HAD THIS KIND OF A PROBLEM. ANY IDEAS AS TO WHY THIS CONTINUES TO HAPPEN?
HELP
I have the same problem with my tv, it goes on and off, the green lights blinks. However my lamp light indicator does not flash when this is happening
I have the same problem only my tv shuts off for about 25 seconds and comes back on.. but my green light stays on...it doesn't blink..any solutions?
