Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
Posted on Jul 07, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have a Zero turn Simplicity Citation with a Briggs 23hp Vangaurd motor on it (424 hours). It was running funny so I took the valve cover off and found a bent intake push rod. I replaced the rod and it ran great for a little while, I thought the problem was fixed. Well, the problem is worse now and it won't even stay running. I checked all 4 push rods again and everything looks fine. Not sure what to do now. Please help.
obsteiner
Level 3:
  • Briggs & Str... Master 901 Answers
  • Posted on Sep 17, 2017
obsteiner
Level 3:
Answers
901
Questions
Helped
311777
Points
7224
I think you have the rocker arm clearance set wrong on the one that you worked on.
See if this video will help -
Lawn Mower Repair Valve Adjustment Twin
5 Related Answers
Anonymous
  • Posted on May 15, 2009
SOURCE: Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jun 27, 2009
SOURCE: Engine smokes and looses power
Check the air filter, replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 3 Answers
  • Posted on Jul 09, 2009
SOURCE: oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
Anonymous
  • Posted on Aug 02, 2009
SOURCE: After about 30 to 40 minutes of use (varies, the
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Anonymous
  • 3 Answers
  • Posted on Sep 17, 2009
SOURCE: briggs motor bent one push rod
This is a vary commom problem with an Intek engine, I have a similar 21HP engine with similar issue. The valve is sticking in the valve guide, the valve guide usually slides in or out. If out, the guide can jamb against the keepers and not allow full valve opening, thus bending the rod. Fix the loose guide and tight valve before you put in another rod, or you will soon be putting more rods in. I think B&S should help everyone on this one. If the guide goes in, it can cause the valve not to close fully and cause a no run condition.
Top Briggs & Stratton Tools & Hardware - Others Experts
Axel Gringmuth
john h
ADMIN Andrew
ADMIN Andrew
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
