37 error is 'pump blocked' It shows when there is little or no change in water level when draining.. It can be caused by a number of problems, but far and away the most common reason is that the pump has something jammed in it! It isn't a big job, but it can be tricky, and the resistance on the pump motor should be checked in case it needs replacing.. A faulty pump can damage the electronics. Empty the machine by baling it out because when the pump is removed any water in the machine will flow from the pump port. A quick job for a tech! Good luck....Nomess
