Sportline C9 by Champion Fitness 910 Watch Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the pace function for? and how should i set it?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Mar 22, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1840821
Points
13581
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SPORTLINE watch manuals.Pace is the relative progress or change of continuous speed.Rate me, please
Set date & time
mcdevito75 here, Generally you need to operate 2 buttons, to set the functions, try pressing the MODE button see the display flashing, press MODE again to see each function, when at the function you want to adjust, press SET, press MODE again to move onto next function, once all functions are set, press MODE for staedy display. If this fails, look for a small watch repair shop in your area for help.
Setting Date & time
mcdevito75 here, generally you need operate 2 bittons to set your Casio watch, the MODE and SET buttons. Press the Mode button, you may have to hold it in for 2-3 seconds, see the display falshing, press MODe to go to each function, once at the function you want to adjust, press SET press MODE to move onto next function, once all functions are set, press MODE for steady display. If this fails, look for a small watch repair shop in your area for help setting up the watch.
I am trying to set the time on my FS1. When I go to the time mode it goes right back to the time display.
On my tips and tricks page is a link to the user manual.
The trick with the FS1 is that you have to wait between button pushes. Don't try to skip ahead of the pace of the watch, it is slow to set anything. That is the rub with 1 button operations.
Push the button, wait for the prompt, enter the info, push the button, wait for the prompt, etc.
if after trying this it still doesn't work you will either need to take it back and exchange or send into polar. There is a warranty service available. Again that link is under my tips and tricks.
1helpful
How do you set the time and date on model 45/6967pnkwm ijust bought it and there were no directions
mcdevito75 here, You need the MODE and SET buttons, press the mode button and see display flashing, now! press MODE again and set each function, after each function is set press MODE to move to the next function, when all functions are set, press MODE again for steady display.
HOW DO U SET THE TIME??
mcdevito75 Here, You need the MODE and SET buttons. Press MODE and see the display flashing, now press set for each function, pressing MODE after eac function is set. Once all functions are set press MODE fpor steady display.
UNABLE TO SET WATCH NEED MANUEL
mcdevito75 here, The 2 buttons needed to set your Timex are the MODE and SET buttons, press MODE and see the display fashing, now press set to set each function, press mode after setting each function to move onto the next function, when done, press mode again for steady display. Here is Timex custermer service info, 800-448-4639, Hope this helps.
Set time on 1440 sports
mcdevito 75 here, You should press the MODE button then, see the display blinking, press set for each function after each function is set press MODE to move onto next function, Hour, Minute etc. Once all set press MODE to stop the blinking and restore normal steady dial.
1helpful
Can't show pace while running
Here you can get proper instructions:
http://www8.garmin.com/support/userManual.jsp?market=67&subcategory=All&product=All
Rate, please.
8helpful
2answers
Garmin Forerunner 50 Train Display Settings
I was having the same problem and came across your post - I figured out how to change the secondary display.  While in Train mode, with your foot pod activated, hold the View button.  The secondary display will change and say "CAD" or "PACE"...keep doing this until you get to the right display.  Hope this helps!
Top Sportline Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Anonymous
Are you a Sportline Watch Expert? Answer questions, earn points and help others
