Sony Ericsson G502 Cellular Phone Logo
Posted on Dec 01, 2009
Java Installer Code - Sony Ericsson G502 Cellular Phone
3answers
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • 0helpful
    Download java installer for samsung notebook 3 windows 8
    Here is the installer for windows 8 for java runtime. I am assuming this is what you need as this is a common plug in. http://javadl.sun.com/webapps/download/AutoDL?BundleId=81819
    After you install Java you can go to this site in your browser in order to see that java has been installed correctly. https://java.com/verify/
    You must restart your browser prior to going to this verification page
    Error 1723
    What you are try to install?
    I guess is a JAVA installation if so try this:
    Please follow the steps below for resolving this issue.
    1. Remove any traces of the failed Java installation by uninstalling Java
    2. Download and install the Windows offline installer package.
    Java download
    There are two version of the Java installer. There's an online installer that the recommend but it only works if you have a decent connection. You can get that from http://javadl.sun.com/webapps/download/AutoDL?BundleId=88627 or from browsing around their website.
    The other (and my preferred) method is to download the offline installer. I have run into fewer issues that way. The link to get that one is http://javadl.sun.com/webapps/download/AutoDL?BundleId=86895
    Java Downloads for All Operating Systems
    13helpful
    2answers
    Downloaded jar files are invalid samsung champ
    You need to download and install JAVA to open these files.
    1. Follow this link: http://www.java.com/en/download/index.jsp
    2. Click on "Free Java Download"
    3. Click on "Agree and Start Free Download"
    4. Click Save File
    5. Open file once it is downloaded.
    6. Click "Install" when the JAVA installer opens.
    7. Uncheck "Include FREE McAfee Security Scan Plus" unless you want this program
    8. Click "Next" and close all browsers.
    9. Restart computer if asked to from the installer.
    10. Open up the jar files you were unable to open prior to installing JAVA.
    That should do it; good luck and thanks for using FixYa.
    4helpful
    Can i get themes for samsung champ
    YOU CAN DOWNLOAD THE THEMES AT THE BELOW SITE......BUT READ THE NOTE BELOW
    http://www.samsungthemes.net/category/samsung_themes/
    Note:
    If you have a problem installing .jar files and seeing "Downloaded Jar is Invalid" message, I recommend you to go to the service center and ask them to update/reinstall java installer as the installer of Champ gets corrupted as soon as you try installing (corrupted) files.
    And if you have a problem with large .jar file size please do the following:
    1.go to keypad in the main screen and then type the following code *#52828378#
    2.select "OTA test" change maximum jar size from 500 to any number you desire (like 2000.)
    3.Save it.
    Now your phone is ready to install the java file not exceeding 2000 kb if you want to install java file of greater size increase the value (number)
    I can only see code (similar to html) on skype chat. how do i fix it and type & see normal text?
    uninstall skype
    go get java from java.com
    re install skype (go get fresh installer from skype.com)
    Aug 06, 2010 • Skype IM
    2helpful
    2answers
    Fatal error during java installation uninstall
    go into Control PanelAdd/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer".
    I click yes and it says "Preparing to remove"
    then configuring java.. and then come up with the window:"Fatal Error During Installation"
    I've tried enabling logging.. it didn't work.. so that's all the info I can give, I have two HD's mounted.. if that helps.. I don't know. I tried using the install again.. it didn't work believe it or not s9.gif. Anyway please help
    No java on phone
    its easy if ur iphone is a original one produced by apple then sonnect it wid itunes and restore it after that itll only support at&t sims and uve to unlok it wid iliberty software for using wid other sims u cn contact me fr dat software at vash_62000@hotmail.com or search on d net and den use any other sim ans then ull get an icon called installer in ur phone by selecting the option of installing installer on iphone from the iliberty menu and then u can download java and its updates from installer via a wifi connection..................simple
    enjoy
    Top Sony Ericsson Cell Phones Experts
    Sudeep Chatterjee
    Sudeep Chatterjee
    Rommel Balcita
    Kolbrun...
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
