I am trying to download and install Java. Halfway through the installation I get the error message 25099 - I have tried everything I can think of including reading a number of online tips all to no avail.
One answer was to delete Java which doesn't exist on my computer because I can't install it - and reinstall it!. I feel as though I am going round in circles.
I have Windows XP Pro and recently reinstalled all my software after a boot problem which is why I need to reinstal java.
How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks..
Error: 25099 during Java installation
This article applies to:
SYMPTOMS
While Java installation is in progress, a message box with the following error is displayed:
Error 25099. Unzipping core files failed.
CAUSE
The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
