Hopefully, you would be ready to solve Amazon Echo Alexa Setup trouble on your own. Are you? Amazing, let's without burning our time, simply look towards the steps recommended below.
Install The Alexa App
To begin the Alexa setup first thing you need to do is to install the Alexa app. To not cause any trouble while installing the app you have to ensure the Internet connection with your device should be strong enough.
When it gets installed you have to sign in yourself. If you haven't created an account there then first create the account. Kindly enter the correct password.
Add The Device
It's time to add your device to the Alexa app. Kindly properly follow the on-screen instructions, it is very important to be followed nicely.
Plug-in The Echo Dot
Connect the power cord to the Echo and wait for the Echo to turn on. If the light is flashing on the device then don't be worried, this happens, it is a part of
Echo Setup on Echo Dot device.
Connect With The Wi-Fi
You have to connect your Echo with a strong Internet network. The Internet should be stable and reliable.
Note Some Points:
- Keep your router at a distance of 4 to 5 feet.
- Do not place it near any electronic gadgets.
- It should be 6 feet above ground level.
- If there would be any objects in between your device ten remove them as soon as it is possible.
We wish that you will succeed to do
Set Up Alexa on Echo Dot with the help of the steps shared in this article.
