Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
SOURCE: lg 47lk520 reset
tried first to disconnect the supply connector going to the inverter board for back light just to ensure if their is no shorted component here. and then turn the power on again if the light stay then the inverter board was the cause why won't power on. by the way did you make a voltage checking at the power supply board does it have correct output voltages 5v,12-16v and the 24v.
