LG 47LG50 47 in. LCD HDTV Logo
M
Mick Gillespie Posted on Jan 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to use manual TV tunin on TV
Channel 7 picture and sound breakup
George
Level 2:
Habit-Forming:
  • Expert 132 Answers
  • Posted on Jan 20, 2016
George
Expert
Level 2:
Habit-Forming:
Answers
132
Questions
0
Helped
28037
Points
436
the LG User Guide can be found here: Download Manuals ,
if manual fine tuning will not clear the problem for you, you may have a signal reception issue which is causing the problem,
How do i stop picture breakup on freeview
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Samsung trouble shooting
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
1helpful
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
My picture breaks up and I loose sound. usually while viewing something I've recorded on my DVR. is it my tv or the cable? or the channel itself?
If it is only during watching a recording on the DVR then it may be the DVR that is the problem. Does a recording always break up at the same point? If so then the recording itself is bad and this may be due to a poor signal being received. If the breakup occurs randomly then the DVR may not be able to read the data from the recording media (Hard disk or DVD - you did not specify). The obvious first step is to try the DVR on another TV.
My Thomson DTI6300-16 is constantly freezing.
This is a problem that i had with my DTI6300-16 it is the main hv capacitor on the psu (22uf 400v) it tested about 18uf so i replaced it,it now is working without picture breakup.i hope this helps?
18helpful
4answers
Philips 21RF vardaan there is no sound but everything works fine
just open the service manual & change the option to 1-128 ,2- 215 , 3- 065 , 4- 000 , 5- 192 , 6- 129 , 7- 112
By-Rajan
Hard Disk recording has sound and picture breakups
Took it to a Philips Service Centre. The hard disk was faulty so it is tobe replaced.
No sound on hd tv on just one station
put tv on ch 2 and locate MTS button and press it till the sound comes back min English
Electrode.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
