Dishwashers Logo
Doug mcdonald Posted on Aug 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E1 error code on omega dishwasher - Dishwashers
Claude Kayser
Level 3:
Top Expert:
  • Dishwashers Master 9,098 Answers
  • Posted on Aug 28, 2015
Claude Kayser
Dishwashers Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5165422
Points
28437
E1 error on LG Dishwasher - YouTube
? 2:40
www.youtube.com/watch?v=2qcwAyHI9ik
Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
5 Related Answers
Anonymous
  • 1543 Answers
  • Posted on Nov 20, 2008
SOURCE: i have error code e1
Hi. Sorry this is so late, but I just happened across this post, so I thought I'd see if you have solved your problem yet. The EI code most often is caused by water leaving the tub during the wash cycle. The most common cause of this is that the dishwasher drain hose does not have a high loop in it. Often, the installer ran the hose right down through the floor. It needs to loop up high before going to the drain to prevent water loss, and a resulting IE code.
Anonymous
  • Posted on Dec 23, 2007
SOURCE: hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Anonymous
  • 110 Answers
  • Posted on Dec 11, 2008
SOURCE: lg dishwasher lds 5811st E1 error code
Hi Chaz,
The impeller breaks on the motor shaft. The motor still turns, but the impeller doesn't, so it doesn't pump water. Because the machine senses there is no water pressure from the pump, it shuts down & displays E1 (it thinks there's a water leak, due to no pressure)
Unfortunately the motor/impeller is only available as a complete assembly
Hope this helps
Col
Anonymous
  • 3 Answers
  • Posted on Mar 06, 2009
SOURCE: LX 40H with Error codes
call me 828-484-9562 can help
Jeff Meyer
  • 423 Answers
  • Posted on Mar 30, 2009
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Top Dishwashers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
