Laid the unit screen down to attach wall mount.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: I have a Proscan 32LB30QD
Remove the 4 screws above the base. The base will slide out.
two_4beach
SOURCE: I can not remove the
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
SOURCE: how to remove base support from PROSCAN LCD TV( model 26LB30Q)
Remove the srews under AUDIO-L/R and HDMI-1.
SOURCE: Looking for a wall mount that fits the ProScan 26LB30QD
http://store.videomountstore.com/ has a tool at the top of the page that gives custom mount recommendations based on the mounting holes for your specific TV. Just choose PROSCAN and 26LB30Q from the list and it will show you the mounts they have that will work for that TV.
SOURCE: Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
