If your Juki HZL-210 Excite's automatic thread cutter is cutting your thread when you're trying to straight stitch, there are a few things you can check:
Make sure you're using the correct presser foot: If the wrong presser foot is installed, it can activate the automatic thread cutter when you don't want it to. Ensure that you're using the appropriate presser foot for your straight stitch.
Check your thread tension: An incorrect thread tension can also cause the automatic thread cutter to activate at the wrong time. Make sure your thread tension is properly set for the type of fabric you're using and the type of stitch you want to make.
Clean the machine: Accumulated lint or debris can cause the automatic thread cutter to malfunction. Use a brush or compressed air to clean the machine, particularly around the thread cutter mechanism.
Reset the machine: Turn off the machine and unplug it for a few minutes, then plug it back in and turn it on again. This can sometimes reset the automatic thread cutter and resolve any issues.
If none of these solutions work, you may need to take your machine to a professional for servicing or repair.
Is the cutting grid getting warm if just warm make sure you don't have any loose wires supplying power to grid. Check grid cutting transformer to make sure it is working. make sure grid is clean. If you are getting power to cutting grid and it's not getting warm then cube let cutter grid is bad. If this needs to be replaced you might thank about a new machine the cost for this part is around 480.00 part number AP2068335
I have questions for you, does the cutting grid have voltage, is so how much? Check the cutting grid for a broken wire also as a broken wire on the cutting grid will cause the same problem. Good Luck
your printer was configed as automatic cutting after print ticket. just go to option -> setup -> setup printer friendly and pick the printer then you will find a option below called "cutting ..."
just uncheck it.
you don't specify petrol or diesel ! If it's petrol (sorry gas ) I would suspect the A.I.C valve requires checking and possibly cleaning, this is the Automatic Idle Control valve, Usaully situated on the inlet manifold close to the throttle body, Cheers
the aquatek 110 power washer has an automatic cut-out for protection function. So its cutting out because its protecting the washer from one damage or the other.
From the look of things, the power washer is faulty, that's why it keeps cutting out.
Any malfunction associated with an automatic shut down usually indicates a
circuit problem or defective component. Unfortunately, the days of taking off the back
cover of your TV and replacing a defective tube or fuse are long gone.
Proper servicing will require troubleshooting procedures that can only
be performed by a qualified electronic repair facility or professional
television repair person. Ask for an estimate and a realistic appraisal
of whether the set can be adequately fixed. Depending on the age and
condition of your TV it may not be cost effective to repair.
