I read the filter under the rubber assembly might be clogged. Dont know how to get to it. Someone mentioned there are clasps that need to be removed. Can't seem to locate them
Below is for Whirlpool/Kenmore, u might find it helpful. Some machines have a small trap door on left front bottom, coin trap.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
