The error code chart indicates that this could be a water flow problem, too low of a drain hose height. Check for clean filters of the inlet water line. Check that the drain host was assembled as per the manual's instructions. In any case your machine is still under warranty and you can ask for Frigidaire's assistance. Good luck!
E10 code indicates there is no water supply.This can be confirmed by :
I know 8 other people with same washer as I have and we have ALL had the same problem within very short time of buying the damn thing - never AGAIN will I buy a FRigidaire. If the pressure switch needs replacing on ALL of these machines - there should be a bulletin and it shouldb e fixed for FREE. It is bull ****.
If your on well water like any washing machine front load or top load every 3 to 6 months you need to disconnect your hot and cold hoses and clean the filters.....
I just had the E10 error with my Washer. (3/9/08)
It turned out to be the pressure switch. $17 part.
We got the error shortly after getting the unit. Was first told it was due to being too much detergent and causing too much suds. So we would use a small amount of concentrate and it was hit or miss on the error code popping up. So on a whim we started using twice as much detergent and haven't had a problem since. Clothes smell and look much better.
I had the same problem and my washer was only 1 month old. Tech came out and looked things over. My pump was clogged. He said that reason it worked sometimes and not others was just were the debris happened to be in the pump.
After 10-15 min after starting the wash - I get that beeping that states E10 - damn it the machine is 2 weeks old - everything is hooked up fine - The appliance compnay did it - now is this common with this machine - or do I return it and get another brand
Same problem.
we have the same problem and have for the past two years, we have to push pause open door then close again sometimes several times...very frustrating hate this washer...
I have had my washer for about 2 years now and just got this message. Where is the pump so I can check it?
