Is the code display L-6? This error code describes US Sensor Alarm.
You may perform the following steps or may ask your local Fujitsu scanner expert for the disgnosys and replacement of faulty part.
1. Does the same symptom occur after turning OFF and ON the scanner? To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check the US Sensor operation by conducting Maintenance mode to see if the US sensor works properly. If the error still occurs, confirm that the sensor cable is correctly connected. And then replace the US Sensor FX and US Sensor RV.
Thanks & regards,
ScanCare
