Computers & Internet Logo
Posted on Mar 24, 2009
Java code for adding octal, hexadecimal subtracting binary,
Java codes for adding octal to octal, adding hexadecimal to hexadecimal
and for subtracting binary to binary and subtracting hexadecimal to hexadecimal
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 25, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
15584
Points
26
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
res
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
  • 1 more comment
  • Anonymous Mar 25, 2009
        Convert Binary to decimal:
    public static long binaryToDecimal(String binary) throws NumberFormatException {
    long res = 0;
    if (binary.isEmpty()) {
    throw new NumberFormatException("Empty string is not a binary number");
    for (int i = 0; i < binary.length(); i++) {
    char n = binary.charAt(binary.length() - (i+1));
    if ((n != '0') && (n != '1')) {
    throw new NumberFormatException("Not a binary number");
    } else if (n == '1') {
    res
    += Math.round(Math.pow(2.0, i));
    return res;
        Convert hexadecimal to decimal:
    public static long hexadecimalToDecimal(String hex) throws NumberFormatException {
    long res = 0;
    if (hex.isEmpty()) {
    throw new NumberFormatException("Empty string is not a hexadecimal number");
    for (int i = 0; i < hex.length(); i++) {
    char n = hex.charAt(hex.length() - (i+1));
    // Try to fix A-F values
    if (f > 9) {
    // A-F
    f
    = f - 7;
    if (f > 15) {
    // a-f
    f
    = f - 32;
    if (f < 0 || f > 15) {
    throw new NumberFormatException("Not a hexadecimal number");
    } else {
    res
    += f*Math.round(Math.pow(2.0, (4*i)));
    return res;
    After you converted to decimal , add or subtract normally. For example x+y =z or x-y = z
    Now take z and convert it back using the following code:
    import java.lang.*;
    import java.io.*;
    public class DecimalToBinary{
    public static void main(String args[]) throws IOException{
    BufferedReader bf = new BufferedReader(new InputStreamReader(System.in));
    System.out.println("Enter the decimal value:");
    String hex = bf.readLine();
    int i = Integer.parseInt(hex);
    String by = Integer.toBinaryString(i); // <---Here you can change the method to "toHex or toOctal
    System.out.println("Binary: " + by);
Top Sun Computers & Internet Experts
Rob Hill
Rob Hill
Narseman
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
