How can I determine the age of my SHU6802UC/U12 Bosch dishwasher? Just purchased home a few months ago and dishwasher stopped working. Trying to determine age to weigh whether to fix or replace.
SOURCE: How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
SOURCE: Bosch dishwasher SHU4326uc/u12 is leaking
I have had the same problem and finally stumbled upon the answer today!
If you are looking inside your dishwasher, look mid way up the right side wall and there is a valve/hole...if that hole is covered up (e.g. cutting board, ect) it will cause water leakage.
Weird huh? But that recommendation is coming straight from the Bosch headquarters in Canada. I would not have believed it otherwise, but I have read this solution twice, and now myself, have not had a leak since I stopped placing things over that hole! My model is SHU3326UC.
SOURCE: Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you
have nuisance water leaks around the base of your dishwasher, you may be using
a detergent that is causing too much suds. Cut back on the amount of detergent
you use, and see if that makes a difference.
Water that spills through the door
vent is usually caused by improperly loading dishes. Leaks from the door itself
may be caused by a faulty door gasket or door tightness adjustment. you should
check the main tub seal, the door latch, the door gasket, the water-inlet valve,
and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet
up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose
connection. Remove the lower front panel, and check the hoses. The pump seal
may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If
this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
SOURCE: New SHE4AM16UC, professionally installed eight
Hi
Thanks
for using FixYa. If the clean light flashes, pauses, and then repeats.
When the dishwasher doesn't sense a water temperature increase, it stops
working and locks the functions (clean light flashes, all buttons are
non responsive). It does this as a safety in case the element is broken and
feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door
and press these buttons in sequence...
-high temp wash
-heated
dry
-high
temp wash
-heated
dry
All the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cycle finish (1-2
minutes). You should now be able to run the dishwasher as normal. If the
issue returns, you could have a problem with the heating circuit (i.e. element,
thermostat or wiring). It rarely happens but it could also be the door
switch not engaging properly when the door is closed (slightly bend the door
latch down making sure it doesn't hit the door when you close it).
Please do
accept the solution if the issue is resolved or else revert for further
assistance.
Thanks
Rylee
