Samsung SGH-E251 Mobile Phone - Black Logo
Anonymous Posted on May 19, 2013
Java codes install - Samsung SGH-E251 Mobile Phone - Black
Which version of java is installed on my computer ?
You can view the currently installed version of java by clicking on the link below:
http://java.com/en/download/installed.jsp
Once at the website, click Verify Java Version.
2helpful
Theres a way to install java applications bigger than 700kb on samsung chat335?
Try one of the following code! (Depending on your Firmware) * # 6984125 * #, then select Internal, enter the security code * # 9072641 * # Continue to select Storage Settings, select the Update Java DB * # 5239870 * #, then select Internal, enter the security code * # 7092463 * # Continue to select Storage Settings, select the Update Java DB for the machine was up tick patch and select "EasyAdminMenu" : * # 3333 # then select Internal, enter the security code is 1111 Continuing select Storage Settings, select Update Java DB
2answers
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
F700v java activation code?
you cannot do that use the java download option beawre you may need to pay for the games
1helpful
Installing java applications and games
hey first of all you need a .jad file for all the java files.
download jad maker from here
http://www.brothersoft.com/jadmaker-25179.html
drag and drop the java files to the jad maker window to create a jad file for that particular java file.
once you're done copy both the java and jad files to the "other files" directory on the phone.
Now exit all menus and type in this code: *#9998*4678255#.You should now get a 'Activated' message. [This is to enable java installation.]
Then go to the other files directory where you placed the jad and java files. Open the .jad file and then click install.
Once the installation is done you can disable java installation by re-typing that code again.
1helpful
Cannot install/uninstall Java
hi,
It is not necessary to install java in order to use java.
Just download java highest version, copy and paste the java software in the system drive(eg C:,D:,....), Then set path the java file.
Example, if you have the java file in your C drive, do the following steps
1. Goto start->Run-> type command. Command prompt(black screen) will open.
2. if it shows as C:> follow the steps, else Goto step 6.
3. set path="c:\Java file name"
4. type javac
5.after typing if u find compiler then Java is installed in your system.
6. Example... if it shows as F:> and if u have saved your file in C:, do the following.
7. cd..
8. cd..
9. cd C
10 .then it appears as C:>, follow from the step 3.
thank you.
2answers
Java illegal arrgument
first press *#9998*5282# then press MIDlet code and the last code is :235282 now jou can install java for free on jour games.
7helpful
8answers
How to install java application and games on J600
For installing games stored on youre phone ( .Jad ) try the java midlet install menu: code *#9998*5282# -> install MIDlet password: 235282
Then you can select a .Jad file (.Jar must be included) stored on youre phone Memory (Stored on MicroSD probable too, but i don`t have one yet)
after install apps/Games, they are in the: application -> Java world -> "My Games" folder (menu-3-4-My Games)
I have the E900XXFF2 Firmware, the password works fine on it. I think on other versions too, because the password was meant for Samsung D807.
enjoy the pass, if it works on youre firmware, but i think it will work :)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
*#1111# Software Version
*#2222# Hardware Version
*#1234# Firmware Version
*#92782# WAP User Agent
*#927827# WAP WAProfile
*#0228#/*#9998*228# Battery profile
* # 0842 # Vib test
* # 0746 # SSMS MEMORY
* # 0638 # SIM SIM network ID
* # 0778 # SST Sim service Table
* # 0289 # Buz test
* # 0782 # RTC (RealTimeClock) (# = Refresh)
* # 9998*228 # Battery Profile
* # 9998*842 # Vib test
* # 9998*746 # SSMS MEMORY
* # 9998*638 # SIM SIM network ID
* # 9998*778 # SST Sim service Table
* # 9998*289 # Buz test
* # 9998*782 # RTC (RealTimeClock) (# = Refresh)
* # 9998*968 # YAMAHA OF OK ONE
* # 9998*76 # Product NUMBER
* # 9998*377 # error memory
* # 9998*5646 # GPRS Logo
Code, whose effect and/or function I exactly do not point
* # 9324 # monitor? (with the red key velassen)
* # 32436837 # DAI ON?
* # 22766 # Automatically Recive call?
* # 227633 # manual Recive call?
!!! RESET code!!!
!!! these codes use only if you know which it does!!!
!!! Thus data in the Handy are deleted!!!
* 2767*3855 # FULL RESET
* 2767*2878 # CUST RESET
* 2767*927 # WAP RESET
* 2767*667 # MMS RESET
* 2767*36245 # email RESET
Top Samsung Cell Phones Experts
Sudeep Chatterjee
Sudeep Chatterjee
vince
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
