LG LFX31935ST Refrigeration : Refrigerator : French door Logo
LINDA FUENTES Posted on Mar 06, 2013
Error code 1f - LG LFX31935ST Refrigeration : Refrigerator : French door
1helpful
I'm getting the error code 1F and it keeps coming back. The water line to the icemaker is disconnected and has been. How can i keep it from coming back?
The error code 1F on an LG refrigerator indicates a problem with the ice maker fan. The most common cause of this error code is frost or ice buildup around the fan. If you have disconnected the water line to the ice maker, then the most likely cause of the error code is frost or ice buildup. To fix the error code 1F, you will need to defrost the ice maker fan. This can be done by following these steps: Unplug the refrigerator or turn off the circuit breaker that powers the refrigerator. Remove all food and drawers from the freezer compartment. Open the freezer door and allow the ice to melt. Once the ice has melted, use a hair dryer or heat gun to melt any remaining frost or ice around the ice maker fan. Wipe away any moisture with a clean cloth. Reassemble the freezer compartment and plug in the refrigerator or turn on the circuit breaker. If the error code 1F persists after defrosting the ice maker fan, then there may be a problem with the ice maker fan motor or the control board. In this case, it is best to contact a qualified technician for assistance. Here are some tips to prevent the error code 1F from coming back: Keep the freezer door closed as much as possible to minimize air circulation. Defrost the refrigerator regularly, even if the ice maker is not in use. Clean the ice maker coils regularly to prevent frost buildup. If you live in an area with hard water, consider using a water softener to reduce the amount of minerals in the water that can contribute to frost buildup. By following these tips, you can help to prevent the error code 1F from coming back and keep your refrigerator ice maker working properly.
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Code f1 f3 f6
virtual machine - VNC send Ctrl+Alt+F1-F6 to server - Unix ...
unix.stackexchange.com/.../vnc-send-ctrlaltf1-f6-to-serv...
Stack ExchangeMar 15, 2012 - Hence I can switch to the TTY's if my CTRL + ALT + F1 - F6 ... As I understand it, you want to send CTRL-ALT-F3 to the remote .... What numeric keycodes do I need to send for the magic sysrq functionality in a VNC session?
error code f1 dishwasher model gldt696tss 00 KVM Switches
www.fixya.com > ... > error code f1 dishwasher model gldt696tss 00
KVM Switches error code f1 dishwasher model gldt696tss 00 questions and ... 6F 23 20 F1 01 = F2 46 B1 59 04 61 77 71 Telewest 00 = 75 4A 66 04 CF 7F 55 F3 ... ...96 F6 1F C4 01 = 6D EA BE 97 6A AA DA 71 NTL 54 01] 07/10/09 00 = F0 ...
kleenmaid f6 code KVM Switches Questions & Answers - Fixya
www.fixya.com > Forum > Tags > kleenmaid f6 code
KVM Switches kleenmaid f6 code questions and answers. ... 01 = C6 64 1D EF 47 5A 0E EF tellywest 00= B7 DE 73 DE 2F A4 F3 BO 01= FA 4B 82 4C ... ...in bradford area plz 5a 01 83 5D 12 B8 96 F6 1F C4 6D EA 8E 97 6A AA DA 71 Hope ..
Not making ice error code 1f
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Washing Machine 8kg - Westinghouse LT8195A is showing fault code 1f. What is the full description of this code please?
I was unable to figure out any error which says 1F. I suppose you wanted to say F1.
Check the fault code status :
http://www.appliancefactoryparts.com/applianceshvac/help-center/fault-codes/fault-codes-washer.html
F1 means Water supply/low water fill .
Thanks
1helpful
LG dishwasher not working showing 1F in timer display
I am not aware of an LG code 1F. But there is an error code "1E"
After you double check that the water valve is open that feeds the dishwasher, focus on the inlet valve (solenoid)
As you remove the inlet valve, if you see the screen is filled with gunk, clean it and retest.
Good Luck!
CF ERROR CODE ON OUR L.G. FRIDGE,WONDERING WHAT THIS MEANS
See pg. 32 of the service manual: http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
This morning I woke up to an error code of 1F. Gotta love LG quality!
Top LG Refrigerators Experts
john h
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
