Microwave Ovens Logo
A
Anonymous Posted on Feb 16, 2013
Error code Hi I have a Swan Sh3021 Dehumidifier, this eveing it displayed a error code on the screen of E1. What does it mean and how can I fix it ??
1 Related Answer
kapishtech
raj somaiya
  • 2272 Answers
  • Posted on Aug 17, 2010
SOURCE: What needs to be done
F1-E1 Defective ERC...Solution: Replace ERC. The error E1-F1 indicates that the Electronic Range Control/Clock has been blown.
  1. Disconnect power to unit.
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the E1-F1 and listen for the beep.
  7. If you get the E1-F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the E1-F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
You can get required parts fromwww.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Top Microwave Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
