I get error code 49 when I try to fax from my HP M1522nf and I have turned it on and off again. Does not work and what is a reformatter card, and where do I get it?
Reasons that Causes Hp Printer Error 49:
The Printer Error code 49 is normally caused by a communications failure between your PC and the printer. The problems that cause this error include:
The Hp Printer Error 49 are communication error codes. They can be hard to troubleshoot as quite a few culprits cause 49 errors. Also, these errors can be just temporary errors that clear with a reboot or more permanent errors that require a hardware replacement. Here are some tips for resolving 49 error codes on HP LaserJet printers.
This Solution will Fix your printer in 5 to 10 minutes approx) if not check my website and contact me for help.
HP printer Error Code 49
Replace the scanner moter
