SOURCE: wii nintendo trying to upgrade it but keep keeping
Usually this is a high network traffic error or possibly a connection error your side with your wireless signal. One thing you could try is changing the wireless channel your router is on.
Hope this helps
Testimonial: "Thank you, I am now connected, very happy."
SOURCE: error code 051099"1 nintendo dsi.trying to get
Error Code: 051099Was this information helpful? Unable to use your wireless signal Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed. How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi." Here's a link: http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp DONT FORGET TO RATE THIS PLEASE
SOURCE: I am trying to download
There may be a problem with your connection on the Wii. I would try erasing the connection on the Wii and starting over. If that still doesn't work, when is the last time you updated?
The Wii may not be able to use the wireless it has because of the broadcast channel from the router. You would need to go into the routers settings and change the channel to either 1 or 11. The default is usually 6 but that tends to be weak. Retry the connection.
SOURCE: no eshop error code 001-0502
Visit this page for a more detailed explanation of your problem, as well as possible solutions.
