Dayton 1DGX4 Dehumidifier Logo
Posted on Sep 06, 2011
E2 error code in display - Dayton 1DGX4 Dehumidifier
What does an E2 code mean? How can I solve that error? I have a Honeywell Dehumidifier model TP70WKN that is about a year old. It have been working well until now that start showing "E2"at the display
Step 1: Reset the printer
  1. With the printer turned on, disconnect the power cord from the rear of the printer.
  2. Wait at least 60 seconds.
  3. Reconnect the power cord to the rear of the printer.
  4. Turn ON the printer, if it does not automatically turn on.
  5. Wait until the printer is idle and silent before you proceed.
Step 2: Update the printer firmware
Click here to know different methods of updating printer firmware.
Step 3: Printing Documents
You can resolve the error by canceling the print job, and then changing the print settings in the printing software.
My Danby dehumidfier model DDR2510E showed the code E2 after I emptied it and now won't work and no where in my manual does it say what to do or what it means.
Hi There,
The E2 error you are receiving is likely the float switch sensor when turns the system off when the bucket is full. Please contact our customer service department to be connected with a service depot in your area.
1-800-263-2629 Business hours are Monday to Friday 9am-4pm
Thank you!
E2 error
Unfortunately, for whatever reason, Haier does not list the Error Codes and what the problem is, in their Owner's Manuals. To find out what E2 indicates you will have to contact Haier Customer Support
1-877-337-3639. It's very important to have your Model Number handy before you call.
Hope this helps you to get the answer. Thanks for choosing FixYa.
1helpful
Quit running and displays E2 in the F/C window.
E2 error indicates that the air intake filter needs to be removed and cleaned. Turn the Master ON/OFF Switch to OFF and unplug the unit, before removing the filter. If you wash the filter, it must be completely dry, before reinstalling it. DO NOT run the dehumidifier without the clean filter installed.
Hope this helped you to solve the problem. Please let me know. Thanks.
2answers
I have a new DE45EK unit that has an error code E2. I powered it down for one hour and the code does not clear. First what is this code as it isn't listed in the guide that came with the product. ...
After turning the Master ON/OFF Switch to OFF, unplug the unit for the wall outlet and wait 12 -15 minutes. Then plug the unit back in to the wall outlet and turn the Master ON/OFF Switch to ON. That 12 - 15 minute timeout, should have allowed the unit to reset it self and clear that unknown code.
Since you are not having success using Haier's Customer Support Number, here's their email address
productinfo@haieramerica.com <productinfo@haieramerica.com>
Hope this helped you solve the problem.
3helpful
3answers
Haier 45 Pint Electronic Dehmidifier Error Code E2
Jason, currently the only 45 pint dehumidifier that Haier sell is Model # DE45EK or DE45EK-L or EK-T. If any of those matches the Model Number of yours, you can down load and print the Owners Manual from the link below. However, the model numbers I listed make no reference to Error Code E2. If your Model Number does not correspond to any of those numbers, your unit is probably no longer manufactured or available.
http://www.haieramerica.com/en/asset/product/4ba7175e54
With that said, there are two things you can do. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then, plug the unit back in and turn the Master On/Off Switch to ON. Did the Error Code clear itself. If so, set the controls as you normally would.
If that didn't solve the problem you can contact Haier Customer Service at 877-337-3639 and they will advise you what to do, to clear the error code.
9helpful
Haier dehumidifier model de45ej-t What does code e2 mean? Unit does not run.
Dehumidifier (DE45EJ-L) shows only E2 on the display -- no "buttons" work. Had been working perfectly -- we turned it off a few days ago. Any suggestions??
2answers
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Top Dayton Dehumidifiers Experts
Steve Pack
Steve Pack
Anonymous
Anonymous
Are you a Dayton Dehumidifier Expert? Answer questions, earn points and help others
