Dell Inspiron 1525 Notebook Logo
Posted on Aug 21, 2011
Error Code 0148 Msg: Error Code 2000-0148 Msg: Hard\Optical Drive 0 - incorrect status: 1A Error Register: 0020H Sens information: (02-0401) Sense data: 70h, 00h, 02h, 00h, 00h, 00h, 00h, 0Ah, 00h, 00h, 00h, 00h, 04h, 01h, 00h, 00h, 00h, 00h
5 Related Answers
Anonymous
  • Posted on Sep 19, 2008
SOURCE: Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
pls solve
Anonymous
  • 94 Answers
  • Posted on Oct 29, 2008
SOURCE: hardware problem - not booting into windows
tosrisri hello,
If you have a VISTA DVD, please insert it, and use the BIOS to boot through your CD.
Then, when the VISTA installation comes up, press repair. Restart, and try again. Please report back.
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on May 29, 2009
SOURCE: to solve code error 0146 and 0148
Hi there.
0146 error is DST Log contains previous error(s).
0148 error is
IDE ERROR: status (x) (s)
This could be a problem with the BIOS, restart the PC and hit F2 as it starts up, this will take you into the bios, reset the bios to default setting, press F10, save and exit the bios, the PC will restart so perform another check and see if the same error code return.
Good luck
mcsecoolguy
Prashant Mishra
  • 93 Answers
  • Posted on Jan 09, 2010
SOURCE: Error 0701 problem in lenovo laptop 3000 c series and N
Try turning on the computer in safe mode and turn on the computer by pressing f8 and see if that works. check in the bios if the cd drive is detected make sure that the disk you put in cd drive is a bootable disk
Anonymous
  • Posted on Feb 03, 2013
SOURCE: error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
