20 Most Recent
Sony KDL-32S3000 32 in. LCD Television Questions & Answers
Sony tv faults
actually tv is not full hd & not sported play station signals through HDMI
How to do a complete factory reset of a Sony Bravia KDL-32P3000
Just talked with Sony Support today.
It seems that Sony in Denmark had sent out new software updates (over DVB-T) but also some wrong TV's got updated as well. This caused my DVB-T tuner to not function anymore so I wanted to try a factory reset and it fixed my problem.
So I was instructed on how to do this. I have a Sony Bravia KDL-32P3000 (which should be similar to the U3000 and S3000 as well).
This is how to do a factory reset of your Sony Bravia KDL-32 P/U/S-3000 TV.
PLEASE BE VERY CAREFUL WITH THE SERVICE MENU, YOU CAN EASILY CAUSE YOUR TV TO MAL-FUNCTION!!!! IF YOU FOLLOW THIS GUIDE IT IS AT YOUR OWN RISK!!!
Set your TV in standy (use the green power butten on your remote), RED standby LED is ON on your TV.
Now press these buttons in this order on your remote (pointing to the TV).
i+
5
VOL UP (+)
GREEN POWER button
NOW BE CAREFUL! Dont press any keys just for the fun of it!!! IT MAY DESTROY YOUR TV.
You should now be in the service menu. It will show up as some green letter/numbers spread over the screen (mine are a bit hard to see/a bit faded). In the upper right corner you should have 2 letters TT (two t's).
Now carefully press key 0 and then key 8 on your remote (they should be shown on the screen after the two TT).
Now wait a little while (more than 10 seconds) and your TV should reset with factory settings, just as if you had just brought it home from the TV store.
Best wishes,
Mads
Has sound but no picture, the screen is black
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
