20 Most Recent LG 37LP1D 37 in. LCD Television Questions & Answers
21answers
LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
12/9/2021 9:27:15 PM • LG 37LP1D 37 in.... • Answered on Dec 09, 2021
2answers
How do I get closed captioning to work on DIsh?
It all depends on the DISH system and the TV. For the most part the CC signal is carried on the cable from the box to the TV. Not sure how you have the DISH connected to the TV, but lets assume its HDMI. Connected this way you should be able to go into the TV settings (use the remote that came with the TV, NOT the dish remote) and go into the settings or menu. From there look for audio. In the audio menu is a section for CC. You should be able to turn it on from there. Or just check on the LG remote. They sometimes have a CC button that you simply push to turn it on. Hope this helps
9/19/2019 4:27:05 PM • LG 37LP1D 37 in.... • Answered on Sep 19, 2019
2answers
My TV on button is not turning the TV on. I tried
Now,what happening to the tv power LED light indicaton,when u turn on the tv now?Tv don't have any power LED light incation at all or power LED light indication is flashing?Check ur power source with other devices,see if the outlet is the problems,if tv still have no power to the tv all.Tv LED power light indication is flashing?Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Now tv should work be again.Still have the same problems,this indication ur tv have a bad or a dead power supply board.That the board,where the tv power a/c cord plug into it.If u understanding basic electronic and have all the tools.Take the tv backcover aparts.Check the tv power supply board carefully for dying capacitors parts,these capacitors parts are dying or dead,most of the times they're bulging up or puffing up onto it tops.Replaces these capacitors parts with new capacitors parts with the same micro ferid but higer voltages like about 5 or 10 voltages higher for better heat resistances and last longer.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
1/11/2019 12:57:49 AM • LG 37LP1D 37 in.... • Answered on Jan 11, 2019
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
4/24/2017 5:04:19 PM • LG 37LP1D 37 in.... • Answered on Apr 24, 2017
Flashing red on light then goes to blue ,but does not come on
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
3/15/2014 11:07:48 AM • LG 37LP1D 37 in.... • Answered on Mar 15, 2014
CC (closed caption) won't show up on DVD movies for LG 42CS570 hooked up with standard DVD player (not Blu-ray). How can I fix that?
Subtitle setting is in the dvd setting not the tv, If the DVD would have CC it would be on the case, CC is encoded in to the tv signal
3/1/2014 7:21:34 PM • LG 37LP1D 37 in.... • Answered on Mar 01, 2014
0answers
0answers
0answers
0answers
Does not turn on
Check power outlet. Change it to another and try. Change input device to something that works. Look for any jammed buttons on the remote. Switch off TV manually, switch off power outlet, remove plug and cool it off for 48 hours and retry. If it does not work even then, this may need attention by a qualified service technician.
7/28/2012 5:21:58 AM • LG 37LP1D 37 in.... • Answered on Jul 28, 2012
LG 37LP1D 37 in. LCD Television Logo
Popular Tags
92 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
no 3 4 volt output
  • Televison & Video
