20 Most Recent Sony KP-57WS510 57" Rear Projection HDTV Questions & Answers
7answers
Starts up then 6 red blinks
http://camerahacks.10.forumer.com/a/how-to-safely-discharge-flash-capacitor_post169.html
please go trough this forum for knowing how to discharge capaciotrs
11/30/2018 10:17:26 AM • Sony KP-57WS510... • Answered on Nov 30, 2018
Sony KP-57WS510 Red Hue to screen.
Misaligned grey scale adjustment. Do a white balance adjustment, after entering its service mode. Contact the authorized service center of any experienced service technician. http://elektrotricks.blogspot.com/ http://electrotechnician.blogspot.com/ http://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/ Please visit these sites to get some details.
6/15/2017 4:06:57 PM • Sony KP-57WS510... • Answered on Jun 15, 2017
My tv looks like its in 3d
The problem is called "convergence" You can get the repair kit here: http://www.amazon.com/Sony-KP-57WS510-KP57WS510-Convergence-Repair/dp/B006B9NN1W I don't recommend that you do this repair if you are not electronically inclined.
11/1/2014 2:47:04 PM • Sony KP-57WS510... • Answered on Nov 01, 2014
The convergence is bad how to fix it
Look in the menu systems. Somewhere in there is a gun aiming tool. Some tvs require this at each start up, annoying, but worth the effort.
8/5/2013 9:08:12 PM • Sony KP-57WS510... • Answered on Aug 05, 2013
I have a Sony KP-57S510 and need to get to the service menu but dont have the remote. Is there a way around using the remote to access it?
On that model I believe you need an original Sony projection remote or one of the "magic tv remotes" that support the convergence function.
4/19/2013 7:26:03 PM • Sony KP-57WS510... • Answered on Apr 19, 2013
Kp-57w5510 screen loss
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this linkhttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull-----------------------------------------------------------------------------------------------
4/10/2013 6:04:30 PM • Sony KP-57WS510... • Answered on Apr 10, 2013
Convergence repair kit used but problem is worse
did you check and replace the two pico fuses on the G board and also the six pico fuses on the D board? If so double check the solder often a pins mounting ring will lift up during the removal and prevent solder connection when doing the install.
1/1/2013 9:12:59 PM • Sony KP-57WS510... • Answered on Jan 01, 2013
My tv is not turning on but the stand by light is still on.
The model listed does not have a standby light, only the power on/off light which is there in case the set does not make it on to blink a error code--specific number of blinksbefore going further can you confirm the model number and add if have sound, or menu etc?
11/3/2012 3:10:34 PM • Sony KP-57WS510... • Answered on Nov 03, 2012
How do i find out if sony kp/57ws510 picture tube is bad
While the set is prone to bad tubes a double or 3d like image is convergence--this model uses two of the STK-392-560 CHIPS for this.Go into customer menu and call up convergence--if off and will not adjust in any area of the screen the chips are bad.
5/2/2012 8:44:42 PM • Sony KP-57WS510... • Answered on May 02, 2012
2answers
Kp-57ws510 convergence problem
Start by replacing the convergence amplifiers IC's.
Are two STK 392-560 and after that redo the adjustments.
3/27/2012 8:07:17 PM • Sony KP-57WS510... • Answered on Mar 27, 2012
Sony KP-57WS510 57" Rear Projection HDTV Logo
154 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony rear projection tv am trying
  • Televison & Video
